12-10-201208:02 PM - last edited on 03-06-202406:36 PM by ROGBot
i have a Fx 8120 thats running a bit hot on the stock cooler. i want to upgrade the CPU cooler but i fear i will have spacing issues in my NZXT Phantom case with the side 200mm fan installed. any recommendations would be helpful.
If you feel comfortable about water cooling you can get the Corsair H80i for $99.99. Offers great cooling and you won't have to worry about the side fan nor RAM clearance.
