Sorry in Advance... Need Ram Advice with B550-F with AMD 5600X
dja2k
Sorry in advance, I tried looking for open discussions on this but couldn't fine any. Mods please move to appropriate place, my bad.
I am building a PC with Asus Strix B550-F and AMD 5600X. I want to order a 3600 CL16 2x16GB kit, but the Crucial is too tall for my cooler clearance and the Corsair not sure if it is a good fit being probably Hynix based. My CPU Ram clearance is 46mm and if I mount the fan higher, it will hit my side panel glass.
https://www.newegg.com/corsair-32gb-288-pin-ddr4-sdram/p/N82E16820236758?Item=N82E16820236758
https://www.bhphotovideo.com/c/product/1548848-REG/crucial_bl2k16g36c16u4w_ballistix_32gb_16x2_3600_...
Nate152
Hi dja2k,
Both will fit.
Corsair Vengeance LPX - 34mm (1.34") tall.
Crucial Ballistix UDIMM - 39.17mm (1.54") tall.
