Should I trade 6900k for a 6850k
TitanXP
I just realized that my rampage V 10th board doesn't support m.2 or pcie raid as a bootable drive, I thought i would need the extra cpu power for Samsung 950 pro raid 0. It also seems the 6850 might have better overall gaming performance.
5 REPLIES 5
meankeys
It has M.2 support?
Yeah it has for 1 drive only but not for raid mode. I decided to order an intel 750 1.2 tb from microcenter since it was only $700.
Well while playing the division and downloading a torrent i go over 60% cpu usage sometimes may just stay with 8 core.
I have the intel 750 installed but it seems to force my gpus into 16/8 mode and have noticed a small hit in fps while playing the division in 1440p 165 hz.
kkn
Level 14
it will drop GPU's down hence the U.2 slot uses pcie lanes. ( as stated in manual )
