Ryujin III and Lian Li Fans - How to connect...
bonifacio
I see a lot of builds with Lian Li Fans and Asus Boards. So there must be an answer out there somewhere.
Sometimes it will say CPU Fan not detected. Set to ignore. The other times, it detects it and displays RPM.
When I do set to ignore, CPU temps will spike high.
Ryujin Pump to AIO. Lian Li Controller to CPU Fan.
What's the proper way to install the controller so that the data will display correctly?
Do you have the BIOS, Lian Li App or Armoury Crate control the fans on the radiator?
I'm assuming most with the 10 Lian Li fan setups are using one controller?
0 REPLIES 0
