Ryujin II 240mm + Ryzen 5 7600X
NandoAoT
Hi all,
I would like to have a advice on my Ryzen temperatures, i moved on from a Intel core I7 4790K where the temps are around 75cº to this ryzen setup, running the OCCT stress test the CPU package jumps to 95cº quickly and and the CPU stay at 84cº, during the stress test the clocks stay at 4889Mhz, so, my questions are:
Are the temps normal for a stress test or my AIO is not being able to handle it? I am using a NOCTUA thermal paste NT-H2 with the ROG Ryujin II 240mm, the radiator is in the front pushing air out and I do have two Noctua NF-S12A 120mm in the top pushing air to inside and another corsair 120mm in the back also pushing air to inside. My concern is that the ryzen may be Throttling..
On regular usage, playing games the temps does not goes over 75cº..
97832
Thanks
0 REPLIES 0
