Ryujin 360 fan header
MaKo82
Just finished putting together a new build, my second in many years, and Just want to make sure I plugged the AIO fans in the right header. I have the ROG Strix z790-E and all 3 AIO fans are plugged into the 3-1 fan cable and plugged into the CPU_Fan header on the motherboard. Should I have plugged it into the ROG fan controller? I dont have enough fan headers on the MB to run all the fans. The booklet isnt specific
Ryujin II 360
0 REPLIES 0
