10-11-2018 01:56 AM
10-19-2018 06:38 PM
10-20-2018 04:30 AM
michaelrw10 wrote:
well, im not even sure that the formula exists. I havent seen it in stock or available for preorder since shortly after the launch announcement was made. Ive got alerts set up on newegg, b&h and amazon .. so as soon as it becomes available (if ever) I will grab one. Newegg just got a huge shipment of XI Code motherboards, so we're moving in the right direction. maybe there is some delay with getting the waterblocks from EK ..
ASUS Support told me that the extreme should be released sometime in the next few months, but not sure when. Maybe I should ask about the formula
10-20-2018 12:17 PM
Silent Scone@ASUS wrote:
Hi, it definitely exists. Have one in a build now. Any two slot cooler (not just 2.7) will obscure the logo when using 16_1 slot. Depending on your enclosure you can use risers with vertical mounts in order to best display the board.
The Formula is aimed more at watercooled rigs. With single slot cards, it's not really an issue.
10-20-2018 12:38 PM
michaelrw10 wrote:
Where did you order yours from
Looks nice,looks really similar to what mine will look like. i have my vector block already here and 2080ti, 9900k is ordered (no telling when it will actually arrive), and im replacing all my old soft tubing with hard line. also gotr a new EK velocity.
The last thing I need to order is the Formula. But i cannot find it anywhere. Newegg got a shipment of Code yesterday, I almost bought one, but I really want the formula. Where did you order yours from? (the only reason i didnt order the formula on day 1 is bc i thought the Extreme would be available but seems it wont be released for a few months)
10-20-2018 03:19 PM
Plenty of tray CPU in stock in the UK currently, I have one coming tomorrow, hopefully. Formula is a sample, but stock should be landing soon.
10-20-2018 03:58 AM
10-20-2018 07:13 AM
pamarakos wrote:
Hi all
Thinking of upgrading my maximus viii formula, 6700k, 1080ti oc strix to the new maximus xi, i9-9900k with rtx2080ti strix
My question is if the rtx since it's a bit "taller" than the 1080 will cover the motherboard's logo
On the viii the 1080 covered only the little upper part of the rog logo, now on this new set, maybe it covers half of it? Does anyone have any clue? I ve got my setup on a core p5 desk-like pc style, so it's going to be ugly, this is why I m asking.
Thanks
P.s. Only one pci express x1 slot on both of these models and placed on the top too?!?!? Why Asus? Can I install my sound card on a pci-express slot supposed to be for a 2nd gpu?
10-21-2018 01:12 AM
barrettusa wrote:
This is my first build for many years (pre-LED) and I also thought it odd that so much effort is made to put something right under the GFX card. Not sure if it helps but this is my XI code with 2080ti.
