I have a x570-E with a Rosewill ATX Mid Tower Gaming PC Computer Case, the CULLINAN V500 RGB. It comes with a preinstalled rosewill fan hub and a switch on the front to control fan speeds.
My conundrum is how can I connect to fan hub to the motherboard for aura sync to function.
Downloading the fan hub manual indicates that I should be able to plug in a micro 3 pin female to a port on the hub and voila. But the rgb cable that comes with the board is a male and larger, also the speed switch on the front is plugged in that port. The hub also has two open led ports that are micro 4-pin male plugs.
Curious if anyone here has encountered this issue and has any idea. I can't seem to find any cable resembling that which they advertise with their fan hub package. Or any that I think would work, And my only idea is to wire the two cables in to the same plug and hope everything goes according plan.. good or bad idea?
