Hi!
Can you help me creating a RAID 0?
When I built the computer I created a RAID 0 volume following the steps in the EZ Tuning Wizard, just like the manual said. It took less than 5 minutes, and I had no problem installing Windows.
I had to format the HD.
Although I'm trying to install WIndows from the same pendrive I used before, the installation says "A media driver your computer needs is missing..." I've already tried another pendrive and a DVD.
I thought it had something to do with the RAID volume, so I deleted it and tried to create a new one, but the EZ Tuning Wizard now says "No available disk drives".
Even if I create the RAID in the Advanced\Intel Rapid Storage Technology option, EX Tuning still doesn't find the disks... and Windows installation says I need the driver.
I've already removed the mobo battery.
The SSDs are OK. I put them in another computer and I could create partitions, format and save.
(After I installed Windows for the first time, I updated to BIOS to version 1002 x64. I don't remember what version it was before)
