10-11-2022 09:04 AM - last edited 3 weeks ago by ROGBot
10-18-2022 01:30 AM
zeblote wrote:
Having received the GPU today, I can confirm that that cable does NOT work. However, the adapter that came with the GPU does.
10-18-2022 04:00 AM
:.Luca.: wrote:
hi, I also have this power supply. I bought it as compatible with the new PCI e. Gen5. I read from your comment that with the new RTX 4000 GPUs it does not work.
A few months ago, with the 3080ti F.E., I had no problems, but it had a 12pin connector.
Does Asus sell a Thor Platinum II compatible cable with the new 16pin connector?
10-18-2022 07:09 AM
10-20-2022 04:29 AM
10-27-2022 07:50 AM
:.Luca.: wrote:
unfortunately I contacted asus Italy and they don't have any available :mad: :mad:
10-27-2022 03:46 PM
Grifil wrote:
So I was lucky as I just received today my Thor Evangelion from Amazon with a 16pin regular 12vhpwr (Eva series is just 3 months old so....)...I would send yours back, and order a Eva, that should have it certainly (I'm Italian as well)...
10-31-2022 01:54 AM
robb543 wrote:
Are you sure that you got the 600 watt cable and not the 450 watt one?
