06-21-2018 05:23 PM - last edited on 03-06-2024 08:05 PM by ROGBot
06-21-2018 05:59 PM
06-21-2018 07:52 PM
NemesisChild wrote:
Hello!
0201 was probably the first bios to be released with this board. Sometimes these initial bios releases are not available to the general public for various reasons.
You do not need to rename the bios file if you're using the EZ Flash tool in the bios.
Have you cleared the CMOS or returned the bios settings to default before doing the flash?
I assume that you're trying to update to bios 1301, right?
06-22-2018 02:59 AM
06-22-2018 10:47 AM
06-22-2018 11:45 AM
NemesisChild wrote:
Have you tried a different USB stick?
09-26-2018 01:26 AM
