05-06-2024 06:50 AM
Hi all,
Just got a question about the ROG Strix LC II 280 ARGB.
Is it compatible with the new Intel 1700 sockets?
I'm a bit confused as on other ROG regions websites it's clearly stated that the 1700 intel socket is supported by ROG Strix LC II 280 ARGB but on the UK website Is not listed on the compatible sockets.
Someone can help please?
Thanks
Solved! Go to Solution.
05-06-2024 09:26 AM - edited 05-06-2024 09:26 AM
Yes, the ROG Strix LC II 280 ARGB is compatible, the ROG Strix Z790-E is socket 1700.
05-06-2024 08:15 AM
Hello Alessio088
Yes, the ROG Strix LC II 280 is compatible with socket 1700.
Check the Tech Specs.
05-06-2024 08:32 AM
Thanks,as I said I wasn't sure as on some Rog website it said it was and in the UK one I couldn't find this information.
Would the cooler be compatible with a ROG STRIX Z790-E?
I think it does mention it is in the specs but just wanted to double check.
Thanks
05-06-2024 09:29 AM
Thanks for your help
