ROG strix helios case replacement parts?
Riviera400
Anyone know how/where to find stock replacement parts for *ROG Strix Helios GX601 case? Specifically I am looking for the Multifunction
cover with GPU braces. I Modded mine to mount my cooling pump/reservoir combo. It came out fine but I am considering additional mods and may relocate the pump/reservoir and will want to replace the one I have due to the holes I made in the stock one.
Thanks*
dogasus
hi, i also want to know this. my front glass is cracked and love to know where to buy the replacement part. anyone helpful enough to help us please respond this thread thanks
Nate152
Hello,
I looked around and cannot find replacement parts anywhere, so I will suspect ASUS does not make replacement parts for this case. I do see some upgrades at etsy that might help in covering the holes.
Customized RGB Panels for ROG STRIX Helios Case Decorative - Etsy
Here someone replaced the front glass panel with a metal haxagon panel, he custom made it though.
Could get creative with this.
ASUS ROG Strix Helios GX601 Front Glass Replacement by Firefist338 - Thingiverse
Rmiller74
Might anyone know where I could get a replacement Velcro strap?
