ROG Strix 4090 OC Power Limit 90%. Why?
MaGiiC
Hello to all.
I noticed that if you use the DualBIOS switch on P the card has the Power Limit set to 90%. However if you set it to Q, the default Power Limit is 100%.
Does anyone know why? BUG in the BIOS? Anyone with the same model of card with the same problem?
*Thanks.
0 REPLIES 0
