Rog Strix 4090 OC power cable question
pan_theo91
Hello everyone,
I am building my new pc and i was wondering which 12pin power cable to use for my Rog Strix 4090 OC, the 12pin to 4X8pins or the one that comes with my Asus thor 1600w P2 power supply which is 12pin to 2X8Pin?
In fact the one that comes with the power supply is thicker so i am not sure which one is better.
Thanks in advance
CycleChris
I just ordered this card, and I have the same question. Also, is the supplied asus cable on the psu side 4 8pins or 3? Thanks!
The one that comes with the GPU is 4 X 8 pins to 12pin
