Rog strix 4090 oc gaming power cable
Swampyg8r
It’s been a while since my last build so the 12vhpwr concept is new to me.  I recently  bought the rog strix 4090 OC white GPU. That comes with the 12+4 to 4-8 pin pcie adapter. I am planning on pairing it with a lian li edge 1300 atx3.1 psu that has a dedicated 12VHPWR connection and 12+4 to 12+4 cable.  Would that one single connection provide ample power or would i still be better using the 4-8pin adapter that came with the GPU?
0 REPLIES 0
