ROG SLI HB Bridge - Need Help
Megalamaniac
I'm looking for the a ROG-SLI-HB-BRIDGE 3 Slot, specifically this one.
https://rog.asus.com/graphics-cards/accessories/rog-sli-hb-bridge-model
I currently have the 4-Slot version, but have upgraded my Motherboard and now need the 3-Slot.
I would also settle for the RGB cable as the one for my 4-slot has broken. The wires on the bridge end connector have started to break off.
Any help would be appreciated.
Super_Gnome
Level 11
Have you tried Ebay? You can often find that kind of thing there, but it might not be right away.
Megalamaniac
Yep, tried ebay and they have tons of non-RGB versions and I got one of those for the time being.
I found a 4-slot RGB HB Bridge on ebay Australia, but no 3-slot.
Pretty much looked everywhere I can think of and have only been able to find one. Problem is, it's at a PC store in Manila and I'm in the southern US and it's already kind of pricey without considering shipping.
