10-02-2022 08:53 AM
10-28-2022 06:41 AM
tcmathews wrote:
Ladies and Gentlyemen,
I could really use some advice. I have an Z690 MAXIMUS EXTREME running an Intel 12900KS, Gigabyte 3080 Waterforce Extreme 12gb. I have 64gb of Corsair Dominator memory with 3 m.2 nvme Samsung 2TB Drives. I play World of Tanks alot and have been getting crash to desktops. This has been going on since March when I built my PC. I have replaced my memory 3 times now, motherboard 3 times, videocard twice. I am not overclocking. I have tried to turn off in my bios everywhere to verify its not a stability issue.
I usually run Windows 11, but I installed Windows 10 on another drive and dual booting for testing purposes. I have all windows updates, motherboard drivers, Armory Crate, Icue, and ESET AV. I am just getting weird errors like this one when I try to install the Audio Driver from the Asus Product Support page:
Example 1:
Faulting application name: rundll32.exe, version: 10.0.19041.746, time stamp: 0xfb4a9a6b
Faulting module name: RtSetupAPI64.dll, version: 1.0.0.14, time stamp: 0x5bcd76b7
Exception code: 0xc0000005
Fault offset: 0x0000000000017ffe
Faulting process id: 0x48b0
Faulting application start time: 0x01d8d61c401f4627
Faulting application path: C:\Windows\System32\rundll32.exe
Faulting module path: C:\Program Files (x86)\Realtek\Audio\USBAud\RtSetupAPI64.dll
Report Id: a9fa5936-b219-4a41-a7e5-7d0f29492e60
Faulting package full name:
Faulting package-relative application ID:
Example 2:
Faulting application name: svchost.exe_Audiosrv, version: 10.0.19041.1806, time stamp: 0x7dcad237
Faulting module name: ntdll.dll, version: 10.0.19041.2075, time stamp: 0x89a237de
Fault offset: 0x000000000002faad
Faulting process id: 0xe98
Faulting application start time: 0x01d8d5dc2189fac8
Faulting application path: C:\Windows\System32\svchost.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: 659d33b5-0464-4742-b9e1-ceed2c2d4cc6
Example 3:
Faulting application name: onePackageLoader.exe, version: 1.0.2.0, time stamp: 0x9fc9685b
Faulting module name: KERNELBASE.dll, version: 10.0.19041.2075, time stamp: 0x923a0837
Exception code: 0xe0434352
Fault offset: 0x0000000000034fd9
Faulting process id: 0x1cd4
Faulting application start time: 0x01d8d5b1e05e2f4d
Faulting application path: C:\Program Files (x86)\ASUS\ROGLSLoader\onePackageLoader.exe
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report Id: ffb0ce7a-123c-421b-bcb7-b3a56597161b
Example 4:
Faulting process id: 0x2e7c
Faulting application start time: 0x01d8d5b1ccae2525
Report Id: 30361cad-1534-4b44-a505-3577414f7c70
Application: onePackageLoader.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.Exception
at Windows.ApplicationModel.Store.Preview.InstallControl.AppInstallManager.Cancel(System.String)
at onePackageLoader.AppInstallFunction.CancelDownloadtApp(installProductNum)
at onePackageLoader.App.App_Startup(System.Object, System.Windows.StartupEventArgs)
at System.Windows.Application.OnStartup(System.Windows.StartupEventArgs)
at System.Windows.Application.<.ctor>b__1_0(System.Object)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at MS.Internal.CulturePreservingExecutionContext.Run(MS.Internal.CulturePreservingExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
at System.Windows.Application.RunDispatcher(System.Object)
at System.Windows.Application.RunInternal(System.Windows.Window)
at onePackageLoader.App.Main()
