rog maximus vii formula bios help
rudeboi
i have just updated the bios to latest version 0901 as i have had a issue with lan everytime i turn my pc on it allways state's i dont have a internet connection but if i do a restart it works but if i shut down then turn back on does the same so thought i would just do a fresh install of the o/s but upon booting from usb it will not show up my m.2 in the select drive to install on so ive tried various bios setting but cannot seem to fix it im not A WIZ KID WHEN IT COMES TO BIOS I i only know basics from trying to read the manual or if i even have set the bios up right at all
anyone able to help/ educate me on what im doin wrong
many thanks
MiLoG
what LAN device ?
Intel® I225-V 2.5Gb Ethernet or Marvell® AQtion AQC107 10Gb Ethernet
try install latest drivers....
Mike_Kelly
Hello Rudeboi, When I look at the VII Formula bios downloads,
3503 4-26-2018
3003 10-28-2015 are the 2 newest Bios that are available.
0901 is something I am not familiar with, so could You please explain where You DL'ed 0901 ?
I do believe the LAN update is much newer then 2018. I have my own card and do not use ROG Lan drivers.
Thanks for the info as I am having a lot of problems with both of the above Bios and could never understand
why Asus would stop supporting such an expensive MB that is still very good in 2021.
