Rog matrix 980ti 2nd monitor blinking
Ryanmt99
Hey
So I'm having an issue with my gpu a dog matrix platinum 980ti runs fine on my rog swift 1440p 144hz g-sync display port monitor however when using my tv as a second monitor via hdmi the tv screen will shut off for a second or 2 including all HDMI audio that was going through the device the tv works fine as a monitor for my gtx 1050 laptop with no issues and even worked fine on the igpu on the desktop mobo the blinking happens more frequently while under load but still occurs even on desktop tried multiple different resolutions on the tv with no solution and the HDMI cable being used has band with for 4k@60 and the tv is also capable of this resolution however the 980ti is the only thing with a HDMI 2.0 port that I have any help would be appreciated as I've tried all sorts to no avail
Thanks
Ryan
System spec
Cpu:7700k
Mobo:maximus IX formula
Ram: corsair vengeance ddr4
psu: corsair hx750i
All at stock speeds no oc applied
0 REPLIES 0
