ROG HELIOS FRONT PANEL LIGHTS NOT WORKING
jpaulocruz15
Still havent fixed it last posted back in January 2022
Hi guys ive got the Helios case since 2020 but a month ago ive decided to turn off the lights for the front panel with the ROG EYE design using the LED button on the top/ front IO of the case. now it doesnt turn back on for some reason anyone can please help? Ive hold the button for 6 seconds as per manual says still doesnt work the light indicator as you can see doesnt work anymore as well? Please help guys. NON OF THIS WORKS AS PER SUPPORTS/MANUAL SAYS ON THE PHOTO ANYMORE!:( Hope someone can help thanks guys.
 271455021_10220038670188455_6851279247028546138_n.jpg271515622_10220038672148504_6106316149386223586_n.jpg
0 REPLIES 0
