10-22-2022 05:26 PM
10-24-2022 09:12 AM
10-25-2022 05:06 AM
pndiode wrote:
I do not use the fan controller but left it in if I decide to sell the case later (power disconnected). The white connector goes to the power supply. The black connector goes to the front IO panel that connects to the Fan switch on top of the case (Low or High). No RGB extension cable required. Front LED RGB cable is long enough to reach the top or bottom connector on motherboard. Put LED Switch on top of case in MB mode when connected to Motherboard 5v RGB. ROG STRIX HELIOS user manual page 14,15 and 16.
