rog front base or oc panel
BigSteve
Just as the title says, I'm gonna be getting the Asus formula vii mono once it's released and I'm not sure what I should get to go with it, the front base or oc panel.
Input plz.
4 REPLIES 4
HiVizMan
Level 40
What do you want to use either of them for? Once you know your purpose then you will know which product you want.
BigSteve
I know for a fact Im going to OC, but is there any main difference between these two items?
HiVizMan
Level 40
Not sure where to find a compare and contrast chart for you.
The panel is great for on the fly OCing as a bencher. But just how much OCing via the panel are you planing on doing? I do not have the front base so can not tell you much about it.
Careful wight h ROG Front Base. I emailed Asus 4 times with no response on getting a longer cable and because i cannot control PWM fans on any of the pam headers with the front base on my RIVBE, so I sent the front base back a couple days before my return period was up. absolutely no support from asus. As long as they keep making decent motherboards ill keep using them. I pray I never have to send anything in for repair or get help on anything.
