ROG Astral LC GeForce RTX™ 5090 32GB GDDR7 OC Edition Radiator position
SimselOr
Hello everyone,
Is it a problem if I install the radiator underneath the graphics card? I have the Lian Li 3000 and the radiator would be at the bottom. Or will there be a problem with the pump due to air bubbles? The question is where exactly is the pump located?
1000 thanks in advance
MrAgapiGC
Level 17
the aio position works as same as aio on the cpu. the pump is on the gpu side NOT on the radiator. so work and obey the same rules and principles of the cpu aio as today.
A picture for reference.
if the pump (on the gpu) is on the middle as reference line, of the aio OR inside the level of the rad is fine. 1/2 position of the tubes. or the rad on the top is fine. if you put the aio on the lower postion or side lower will have the same as aio situation. no changes on how that woks.
On the second is fine
as meme on jay
Also a NONO on both sides.
When this DOES NOT APPLY: when the pump is on the radiator
For better undestanding (recomendations)
Learn, Play Enjoy! We help and collaborate, NOT complain!
mockridge09
If the pump is in the radiator, mounting it at the bottom could trap air bubbles and cause issues. Maybe check with Pearl Lemon Commercial Repairs for advice.
