riser cable?
xreaperx22
hello im getting ready to order the asus rog strix helios gx601 pc case but i want to know which riser cable would work for installing a single gpu vertically,i dont want to get the case only to find out nobody sells a riser cable for it lol which im sure isnt the case,but if it is i wont be buying it,so any help here would be greatly appreciated thanks!!
Asus Maximus VIII formula Z170
Intel I7-6700k 4.0 {oc to 4.5}
Custom Water Loop
M.S.I 980ti 6GD5T OC
32GB G.Skill RipJaws 4 2666 {oc to 2700}
Samsung 950 pro nvme m.2 512gb
Seasonic flagship prime titanium 750watt
ThermalTake Core X9 Snow Edition Case
PSZero
Well...cooler master sells some good quality risers, AVOID for all means the termal take ones, aswell, if you're gonna order the pack riser plate + cable from coler master, take in mind the cable is a lot shorter than the one that comes with no plate... so check how long you need it before you buy it
