RGB LED's MIssing - STRIX 1080 Gaming
JimmyH
Level 11
Has anyone else had an issue where half the LED's on the GPU are missing or dimmed. Please see attached picture. This happened quite a few weeks ago, but I thought it was just the angle of the light in the room, added to that I haven't been on my PC for a while.
Things I have tried:
Uninstall/Re-installed AURA
Uninstall/Re-installed Armory
Updated to latest drivers.
Have unpluged PSU and reconnected, same with PCIE slot.
The first two LED's are dark, the middle ones dim, and the end two lit.
I have also tried different settings on AURA.
Help please
82788
MrAgapiGC
Level 16
Help please
82788
That is not issues with aura. That is the plastic tube being crystallize. There are only 2 led diode there. You need to replace those. Is easy there is a post somewhere here im order to check how is done and what size (diameter) but is easy.
https://rog.asus.com/forum/showthrea...RGB-LEDs/page5
Learn, Play Enjoy! We help and collaborate, NOT complain!
here is the link
https://rog.asus.com/forum/showthread.php?99996-Strange-issue-with-1070-Strix-RGB-LEDs/page5
