RGB Connectors
MrSamyClash
Hey Everyone,
I build a PC and now i have a problem.
The RGB Connectors are different to the others i have. I use a RGB Hub (Raijintek) to connect all the cannels togheter and then to the Motherboard.
To problem is the size of the connectors, 4 of them are little and the other 3 are big so i can`t get all of them to the same Hub. The Hub has the big Connectors. All RGB Devices are Asus Aura verified
So does someone know how to connect the different connectors togheter, or is there something like an adapter?
PLS respond me.
Thanks
Greetings
UltraNEO_
Level 11
MrSamyClash wrote:
Hey Everyone,
PLS respond me.
Thanks
Greetings
From my understanding, you should not use other people's RGB controllers on the Asus motherboard because the specifications and the technology is different. Doing so may damage the Asus motherboard and void your warranty.
However, you can use 'standard' 4 pin 12v RGB LED strips directly to the motherboard, but ONLY install 12v RGB light strips to the 4 PIN header but DO NOT add any third party controller(s) - Those can damage your motherboard - You can manage the lights using Asus's Aura software.
The 3pin header is also different. It's based on 5 volt digital technology. To use this port you need to buy compatible Aura Sync products and lighting strips.
ASUS ROG RVIE Encore| i9-10940x | Dominator Platinum 128GB 3333 MHz | EVGA RTX 2080 Ti SLI | Samsung 970 Pro 1TB NVMe (x3)
WD Black 4TB | WD Black 6TB x2 | EVGA 1600 P2 | CaseLabs SMA8 | Custom Water Cooling | HWLabs Black Ice Nemesis GTX 560
XSPC RX 480 v3 | XSPC D5 Vario x2 | EK Blocks | EK-RES X3 400 | BitsPower Fittings | GentleTypoon 1850 x12 | Corsair SP140 x8 | Lamptron CM615
Twitch.tv/MsNikita | Twitter.com/MsNikitaTV | Instagram.com/MsNikitaTV | Reddit.com/r/MsNikitaTV
