Replace CPU Retention Bracket
OutSider420
I’ve misplaced my Asus XI Apex CPU retention bracket and need to get a new one. How would I go about it? Will contacting support get me one or do I have to buy one from a 3rd party?
Nate152
Hi OutSider420
Probably easier to purchase one as ASUS would likely want you to send the motherboard for repair.
I believe you're looking for this?
https://www.trustedparts.com/en/part/te-connectivity-amp-connectors/2013882-1
Thanks I’ll check those out
