Hi there.
I have just installed a small temperature sensor which I've attached to the middle of my DRAM modules so I can see what they're getting to under load. The sensor is attached to the 2 pin tmp connector at the bottom of the board. Please note I'm not using the tmp opt pins, I'm not trying to control fans, just read a temperature.
This is all fine, but how do I read the sensor? What software do I need to read this data?
Thanks folks.
