Rampge 5 extreme 950 pro slow boot.
NuMetal93
Just picked up a 950 pro and am experiencing slow boot times. I read this guide(https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjElMDCnofNAhUJej4KHVz4CX0...) but did not change PCIEx8 and m.2 setting until after I installed my windows in UEFI mode. Even after I changed the setting to m.2 I am still experiencing slow boot times. NOt sure how to fix this or if any one else has had this issue. Any help would be much appreciated.
PC specs:
Intel 5930k
Rampage5 extreme
3x gtx 980s
2x intel 730 ssds
32 gb ram
1300 watt psu.
5 REPLIES 5
drop4205
Level 12
What bios are you running? Any oc on anything? Have you tried after doing a clear cmos or going into bios and hitting default setting
Maximus XI Formula, I9-9900k, Phantex Evolove X, Seasonic Titanium 850W, Custom loop PE360+SE360 Rad, G.Skill Trident Z F4-3200C14 32g, Nvidia Reference RTX 2080 TI, Samsung 970 EVO Plus 1Tb, Windows 11
NuMetal93
I beleve rev 2001, but I think my issue has to do with me installing windows before I set PCIEx8 to m.2. I have no over clock but I did take volts off my cpu to try and combat thermals. Im running at like 1.25 volts at 3.5 Ghz or something. im about to flash my bios so ill have t o do it over anyway.
NuMetal93
yes, I used rufis and installed in UEFI mode via a usb.
Chino
Level 15
