Rampage VI Extreme Omega - Corsair H80i V2 Question
Joe45
I'm getting a Rampage VI MB and a Corsair H80i cooling system. Since it isn't a Asus water cooler (don't have room) will I be able to utilize all the functions in the bios and monitoring for water cooling; speed, temp, flow, etc. with the H80i. The H80i connects via a USB while the Asus connects by SATA. I tried searching for information about this and found nothing except the USB connector taking up two spaces on the USB header.
Thank you
Joe45
The Answer is no. You will have to use the Corsair APP ... Icue
Thank You for ALL the great responses :rolleyes:
