Rampage VI Extreme (how to remove cover?)
Tobarus
Ok,
So I'm in the process of installing my Rampage VI Extreme, but realize 2 of the mounting holes are covered by the ROG eye logo. (also underwhich one of the M.2 slots are).
Does anyone know how to remove this cover? I see one black screw between the last 2 PCI slots, but do you just pry the cover off after removing the screw? The plastic seems pretty fragile, and the last thing I want to do is break it before it's even installed!
Thanks for the insight!
Anicra
I hope you figured it out, however lightly push straight up and it will pop off, at least that what I did (like taking an emblem off a case ..like feeling)
I7 5960X/Asus RE5u3.1 -3101/64gb(16x4)@3133 @1.39V Gskill 14-15-16-36 cr2/3xTitanX/ WD RE 6.0 TB RAID 0+1/Samsung 840 Pro 256 x2 Raid 0/Samsung 850pro M.2/Asus Essence One/Corsair Ax1500 PSU /Corsair Obs 9800D case/ 3 2xRad 120x3 and 120x1/ EK MB block/AquaC Kryos CPU/Koolance GPU x2/ Bay 452x2(ver2) (2x655 serial)
There is a small screw in between one of the pcie slots that links to the eye logo. Take out the small screw and lift straight up. It will pop off. It also gives you access to the m.2 drive under the logo. Hope this helps
