Rampage V Extreme Fresh build will not turn on
Latency_Remix
Howdy all, Just wondering if i can get some advice on a situation that is happening.
Just finished putting together this new system for a friend and went to boot it up to install windows on it.
Specs:
V Extreme
Dominator 15gb DDR4
EVGA video
Corsiar closed loop water cooler
1200AXI PSU
What's happening is when it is turned on, lights and fans all light up, It posted once, something about CPU fan not there. Which i then re pluged the power from the water cooler unit into the CPU fan power and tired again.
It now power's on, wait's for a few moments and then power's down with nothing appearing on the screen.
Please some advice would be welcome
6 REPLIES 6
Latency_Remix
After a bios reset via the back button, i was able to start the windows installation. During which when it want's to reset the PC multiple times it would not auto restart, and has now gone back to doing the same thing, powering on then off
Latency_Remix
Now its giving code 6F saying overclock is incorrect when i haven't touched a single thing on the OC settings
Latency_Remix
I7 5960x
Corsair AX1200i
EVGA GeForce GTX 970
Corsair Dominator Platnum 16gb (4x4)
Rampage V Extreme
Corsair Hydro H105
WD Red 2TB X2
abvolt
Level 11
are all power connectors on the board plugged in, the 8 & 4 pin..
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
Chino
Level 15
