Rampage IV BE build advice
XxDeadlyViperxX
hi everyone new member to the forums but have read some of you threads for the past few months.
Im building a gaming rig for my nephew. nothing fancy but want him to have some power in his rig for max settings.
he mostly plays mmos( lortro,rift, wow, etc) but MB came with AC Black Flag so he might play it want it to look awesome for him
Budget: not an issue i save for what i want.
Main uses of intended build: gaming
Parts required: looking for recommendations on these items
:confused:
cpu: unsure what good enough and not overkill; like the i7 4960x maybe a 4930K is good enough for his needs?
vid card:this is confusing alot of options not sure which is best. hoping for a single card solution gtx 780 titan or ati?
memory: what has been the solid choice and how much is plenty?
build information (list details of parts): parts that i have already
chasis : Thermaltake Chaser MK-1 VN300M1W2N (Black)
MB: Rampage IV BE :cool:
psu: Corsair Professional Series 760 Watt Digital ATX/EPS Modular 80 PLUS Platinum Power Supply AX760i
sound card:Creative Labs Sound Blaster X-Fi Xtreme Audio 7.1 Channel PCI-Express Sound Card
Monitor resolution: i would like an awsome monitor for him 27"-30" suggestions?
Storage requirements
: havnt purchased these yet so speak up if you have a better suggestions 😄
Samsung Electronics 840 Pro Series 2.5-Inch 256 GB SATA 6GB/s Solid State Drive MZ-7PD256BW
Western Digital 4TB SATA III 7200 RPM 64 MB Cache Bulk/OEM Desktop Hard Drive, Black, WD4003FZEX
Will you be overclocking: no
Extra information about desired system:
even though not over clocking i thinking of a simple solution for cooling the cpu using a
Corsair Hydro Series Extreme Performance Liquid CPU Cooler H100i
what you guys think
thanks in advance!!! 🙂
17 REPLIES 17
Chino
Level 15
Welcome to the ROG forums, XxDeadlyViperxX.
You pretty much have chosen all your components so I'll help fill in the blanks.
CPU: Intel Core i7-4930K Ivy Bridge-E 3.4GHz
RAM: G.SKILL Ripjaws Z Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 2400
SSD: SAMSUNG 840 EVO MZ-7TE1T0BW 2.5" 1TB
GPU: ASUS DirectCU II GTX780TI-DC2OC-3GD5 GeForce GTX 780 Ti 3GB
isnt the ssd just for your wondows and app installs or is 1TB because of games sizes?
atleast most of those components are cheap.. thats a relief i dont mind spending the money but not if I dont have too. besides not like its gonna be my computer lol
kkn
Level 14
as chino listed, will give you the top of the notch.
PS: chino you forgot the monitor 😛
mabye one with G-sync?
Arne_Saknussemm
Level 40
Yep, I'd say Chino's recommendation is pretty much spot on. If you are willing to wait a bit maybe wait for a Matrix Platinum 780Ti or even go for a Titan Black...but they are all pretty similar.
Monitor is tricky....ASUS is launching PB287Q 4K monitor but this resolution would likely need a couple of high end cards to run it...like a couple of Titans...
The ROG Swift PG278Q is upcoming but again when exactly?? it will be a great gaming monitor with GSync technology...
Readily available is the Dell U2713HM....not strictly a gaming panel it is very good and being IPS has better colours etc. for anyone who likes photography and not just games....
For 60fps at 4k, you need dual GTX 780Tis, R9 290xs, or an R9 295x2, or dual TBE.
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
around summer time have been the last info put out.
atleast I can add another vid card later if its necessary.
abvolt
Level 11
4k monitors still too spendy for a good one the rog swift at 1440p & 144 hz looks to be a really good choice..
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
