Rampage Extreme iv - CPU_FAN vs CPU_OPT vs OPT_FAN
S_thian
Can someone help me with these definations and it's functions.
CPU_OPT?
OPT_FAN?
I plan to install a CoolerMaster Seidon 120M.
It has a radiator fan 4 pin wire and the cooler waterblock itself with a 4 pin wire also.
Do I connect the radiator fan to CPU_FAN or CPU_OPT?
Likewise which for the Cooler waterblock 4 pin wire?
Many thanks in advance.
Nackers
Level 15
Hi S_thian, welcome to ROG.. Connect your fan to the cpu_fan,, I have my pump connected to the psu via an molex_fan adapter (most cases come with the molex_fan adapter for the case fans) so my pump is running flat out all the time...... others would advise you the connect the pump to the cpu_opt so you/bios can adjust it's speed..
