Ram upgrade not working?
Vizard
i recently upgraded my ram to 24gb yet my programs keep my disk at 100% and seem to not use much even any of the new ram i had installed.
i am using a G75vx
installed 2 gskill 8 gig ripjaw ram sticks-24.0GB Dual-Channel DDR3 @ 665MHz (9-9-9-24)
im not sure if this has to do with it but it says Memory Usage 13 % under speccy while im running all this stuff
all im doing is transferring files to my desktop,using internet and other programs, and winrar
some one aid something about Memory Remapping [enabled] to me
13 REPLIES 13
Zka17
Level 16
Based on the specs on the Asus site, this laptop has dual 2.5" bay for storage units...
Vizard, where are you located? In US you certainly can find an SSD below $300...
Okay, so he puts his OS on the 256GB SSD previously referenced from Amazon for $139 or $160 at Newegg and everything else stays on the other drive. He can stick that in as a secondary and copy from it when he does the HDD switch.
Samsung makes a migration software that it comes with that lets you copy your old HDD to the SSD. It's custom so I would suggest you go through and let it copy C:\ Windows and the system partition and exclude all your videos and game folders \ program files (x86\ etc.
Mobo: Rampage IV BE | CPU: i7-4930@4.5ghz Hexacore | RAM: 32GB Corsair V-Pro | GPU: 4xR9 290X Quadfire | PSU: eVGA P2 SuperNOVA 1000W\G2 850W | Chassis: NZXT Phantom 820 | Cooling: XSPC Raystorm CPU Block\4xEK 290X Block\2x Laing D5\XSPC Dual Bay Res\Phobya G-Changer 1080 External Rad\Alphacool 140UT60\XSPC AX360 | Fan Con: Lamptron CW611 | Tube: Primochill Adv. LRT Bloodshed Red | 3xCrossover 27" 2560x1440 Monitors | Build Log of Insanity
Zka17
Level 16
128GB SSD is way enough for Win7… (with the original HDD as data storage, of course)
Chris_Manico
Od that you have 24 GB of ram I take it your using 3x 8 GB sticks? Wouldn't that affect performance by not being in dual channel mode? ANd I'm going to have to agree , an upgrade to a SSD would have been my first priority.
Corsair Carbide 540 Air ~ AMD FX 8350 ~ Asus Crosshair V Formula Z ~ 1901 BIOS ~ Corsair Dominator Platinum 2400 MHz 2x8 Gb CMD16X3M2A2400C10 ~ EVGA GTX 1080 Ti ~ Corsair AX860i PSU ~ Samsung 840 Pro 256Gb SATA 3 SSD ~ WD 4 TB 7200 RPM 64 MB ( RMA'd ) ~ Creative Sound Blaster X-Fi Platinum ~ Corsair SP2500 2.1 Gaming Speakers ~ 27 Samsung SA550 HD LED Monitor ~
