I might not have been very clear and I apologise for that, while your ram was designed for Intel systems it will work on your board just fine. However you will not get the 2400MHz speed. That is all. There are very few kits of ram that are specific for AMD, Intel is king right now and ram is made for the mass markets. One key exception is AMD they market there own specific ram kits.
BUT your ram is very good, you will get great speed out of it and all it will take is some tweaking on your part. All the world records for frequency on AMD boards were done with "Intel" ram.
