Ram help for rog strix 570-e gaming wifi 2 motherboard
CarlChilders
Hi and thanks in advance for any help I have ram for the mother board gskill trident f4-3600C18Q-32GTZR it's similar to all the gskill on the qvl list I wanted to know if it might be ok to use in my build since it seems to be a configuration problem more than any other issue. Thanks again.
Silent_Scone
Super Moderator
Hi @CarlChilders
If unsure and having to ask such questions I would recommend sticking to kits that are present on the QVL.
For more insight into XMP/DOCP/EXPO please see here
