RAM for X399 and Threadripper,need help.
ksyado3200
Hi, everybody. Need help selecting RAM. Motherboard ASUS ROG Strix X399-E Gaming,CPU AMD Threadripper 1920x. I select the memory from the motherboard QVL list, there is G.Skill F4-3200C16Q-32GTZR memory, but the G.skill website says that F4-3200C16Q-32GTZR is an Intel version, and F4-3200C16Q-32GTZRХ for AMD, which believe them? Will this memory work on my motherboard at a frequency of 3200 and with the stated timings?
F4-3200C16Q-32GTZRX in my country is not for sale, very sad.
Thanks in advance for your reply.
Arne_Saknussemm
Level 40
If it's on the QVL then it has been tested working.
However 3200 is an overclock frequency...it's not guaranteed to work...and might need the user to make adjustments in the BIOS
Overclocked frequencies are not guaranteed because it depends on a lot of factors coming together, not least of which is the actual CPU sample and it's memory controller strength.
