02-13-2017 08:50 AM - last edited 3 weeks ago by ROGBot
02-13-2017 11:23 AM
02-13-2017 12:59 PM
Nate152 wrote:
Hi mjohnson24
All fan headers support up to 1A or 12 watts, the high static pressure fans you listed are rated at .18A. 4 fans x .18A = .72A which still lets you some headroom so you could put all 4 for the cpu on the cpu fan header or 2 on the cpu fan header and 2 on the cpu_opt header. All other fans would go on a chassis fan header which are rated at 1 amp too.
Or you could just get a nice fan controller.
With 2 pumps I'd connect them to the psu and have them running 100%.
02-13-2017 02:27 PM
02-13-2017 02:59 PM
Nate152 wrote:
Here is a nice fan controller that could control all your fans and then some.
Lamptron FC5 - V3
6 channels at 30 watts per channel, the LCD can change to any color.
http://www.lamptron.com/product/controllers/fc5-v3/
https://www.amazon.com/FC5-Channel-30W-LED-Controller/dp/B00DQSTP0O
02-13-2017 04:49 PM
02-13-2017 05:05 PM
Nate152 wrote:
You can control every fan in your case with the lamptron fan controller, each of the high static pressure fans draws .18a or 2.12w, 10 fans on 1 channel would be 21.2w, so you could put 60 fans on it if you wanted.
I have an external cooler the koolance ERM-2K3U.
