Question about Maximus V Formula CPU and Video Card power
Kinesis22
Hi, I was wondering if the 8 pin cpu power on the Maximus V formula would be necessary for a Intel i-5 3570k Ivy Bridge processor. My power supply doesn't have an 8 pin cpu cable so if I do need the 8 pin would there be any adapter? I have a Seasonic ss-700hm psu. Also, I was wondering if , since my psu didn't come with the second 6 pin pci-e modular cable, would my video card get enough power to run well if I use a 6 pin pci-e Y splitter to power my Video Card? I have an EVGA Nvidia GEForce 460. This will be my first build and I'm kind of confused about it.
~Kinesis22
EDIT:
Okay here are the parts I am thinking of using to build this computer:
Motherboard: Maximus V Formula
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131854
CPU: Intel i-5 3570K
http://www.microcenter.com/single_product_results.phtml?product_id=0388577
HDD: Western Digital Caviar Black 1 TB SATA III 7200 rpm
http://www.amazon.com/Western-Digital-Caviar-Internal-Desktop/dp/B0036Q7MV0/ref=sr_1_1?ie=UTF8&qid=1...
Video Card: EVGA Nvidia GEForce 460
(I have this already)
RAM: Corsair Vengeance 16 GB Dual Channel 1600 MHz 240-Pin DDR3 SDRAM
http://www.amazon.com/Corsair-Vengeance-Channel-240-Pin-CMZ16GX3M4A1600C9/dp/B004E0ZKLQ/ref=sr_1_15?...
Optical Drive: ASUS 24X DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Chassis: NZXT Phantom Black Full Tower Case
http://www.amazon.com/Crafted-Series-Tower-Steel-Chassis/dp/B003WE9WQY/ref=sr_1_2?ie=UTF8&qid=134361...
PSU: I have a Seasonic M12 SS-700HM but that is possible to change if it wont work.
My goal is to keep this under $1050.
If I missed anything or if any of the links are wrong let me know.
~Kinesis22
~Kinesis22
"Since there's only one of me shouldn't my opinion be doubled?"
"Is it possible to play that game in your sleep?" "Oh definitely, I think better in my sleep."
65 REPLIES 65
HiVizMan
Level 40
100's of thousands of folks have been using Sandforce controllers with maybe a couple having issues. The whole thing about Samsung is that their controller is ultra stable and that is what Enterprise customers want. The Sandforce will be quicker in benchmarks but both will be the pretty much the same in real world.
The later versions of the Sandforce controller firmware update sorted out those few problems that users had. So I think you can select which ever you prefer. You will be happy with either type. Currently the best bang for buck has to be the Sandforce based controllers look around there are a couple of great bargains. Way under £1 per GB.
Kinesis22
Ok, what is the difference between this
http://www.amazon.com/Windows-Premium-64bit-System-Builder/dp/B004Q0PT3I/ref=pd_bxgy_e_text_z
and this?
http://www.amazon.com/Microsoft-Windows-7-Home-Premium/dp/B002DHGMK0/ref=pd_cp_sw_3
~Kinesis22
HiVizMan
Level 40
The cheaper one is OEM and is for one machine (one build only) the other is DVD retail and for one user and more than one build.
Me I would download the Win7 Ultimate 64 and trial use it for three months - this is legal and allowed. Then get Win8 when it is released.
Kinesis22
Ok thanks, how do I get the trial when I build the computer? Do I download it and write to a disc or something?
~Kinesis22
fronzel
Yes, download it directly from Microsoft and burn to a DVD.
Or you can use "Windows 7 USB DVD download tool" to create a bootable USB stick instead of burning to DVD.
ASUS Maximus V Formula | Intel 3770K | Corsair Vengance 4x4GB 1600
ASUS GTX 680 DC2 TOP | Seasonic X-760 Gold | Lian Li PC70
Samsung 830 256GB | WD Green 3TB | Dell U2711 | Win7 64
Kinesis22
Where do I download the trial from?
~Kinesis22
Looks like Windows 8 is the only one currently available for trial download:
http://windows.microsoft.com/en-US/windows-8/release-preview
Kinesis22
I found a Windows Enterprise trial would that work? Also, would running Linux work fine too until win8 comes out?
~Kinesis22
I you are going to run a trial, it might just as well be the Enterprise version.
If you want to run Linux, go right ahead.
Kinesis22
Awesome! Thanks, I think I'm going to research Linux a bit.
~Kinesis22
