Query RE Rog Zenith Extreme onboard OLED display
FalloutBoy
So I don't have to rip my system apart.. yet.
On page 1-26 Item 16 Shows an OLED header, I am assuming that this is an expansion header for another OLED display so that you can have one at the front of the case if you want to.
If that is a correct assumption:
What is the ASUS part number for the additional OLED? , Does the OLED cable supplied with that unit have various lengths?
If it is an incorrect assumption:
If the header is used for the existing display and I want to move it to the front of the case does anyone know ( again without me ripping apart my system ) how long the OLED cable supplied is?
Thanks in advance.
I truly believe that there are people on this planet who should voluntarily remove them selves from the gene pool.
Maximus IV Extreme Z/16G/2600K, Rampage V Extreme Edition 10/32G/6900K, G751JY-T7042H
Zenith Extreme Alpha/64G/2950x , X399 Prime A/32G/1900X
Power Mad Mu ha ha ha
0 REPLIES 0
