Quad 7970 Watercooling
xNovax
I am looking to water-cool my quad crossfire HD 7970 set up. Id like to watercool the GPUs and the CPU.
I would like to use these water blocks for the GPUs http://www.frozencpu.com/products/16056/ex-blc-1110/Swiftech_KOMODO_HD7970_Full_Cover_VGA_Waterblock...
I am looking for recommendations for the waterblock for my 3930K and I would like some recommendations on radiators and pumps.
I currently have the NZXT switch 810 but I am willing to change the case if it is needed.
Rampage IV Extreme
I7 3930K @4.4 GHz
16GB G.Skill RipjawsZ @1600MHz
Quadfire MSI lightning 7970
Dual XFX 1250watt
4 REPLIES 4
Arne_Saknussemm
Level 40
That is a lot to cool in that case without heavy modification I reckon. You will be looking at 2 360s minimum I reckon. The EK stuff is great stuff. I have the full nickel Supreme block and like it a lot. There is a new Supremacy which shaves a further 2 c off according to EK.
Maybe a couple of loops would serve you best for that I would run a couple of their DCP 4.0 pumps (I have one and it runs great...and quiet) and their radiators are great if you want to run lower static pressure fans for a quiet system. If you don't care about noise go for higher fin density rads and loud fans;)
kkn
Level 14
you can fit 1 360 or 1 420 in the top or 1 240 or 1 280 in the botom and whit front panel off in front you can add a 280 ( i dont know if it wil work or not )
or you can mout one 360/420 on the outside back whit a mounting kit.
for the 240/280 in bottom you have to trow away the botom HDD tray to fit it.
im "moding" mine now ( over kill( in the mod/build section ) )
and for the pump i have i had to trow away all the HDD trays to get it mounted.
Krindor
Level 11
I would recommend a dual loop one cooling the cpu and one cooling the gpus. For that either a dual pump bayres combo or just 2 separate pumps and reservoars. For pump any DDC pump will be able to handle the flow, otherwise a D5 pump for the GPU loop. For radiators I would recommend Alphacool nexXxos as they are the best performing on the market and have a very good price with one 360 for the gpu and one 240 for the cpu or if you're able to get a third rad use that for the gpus as well. For waterblock The Swiftech Apogee HD and Alphacool nexXxos are the best performing but they don't look nice so for a great looking and performing either EKWB Supremacy or XSPC Raystorm.
| Chassi: Phantom Fulltower White Edition | Mobo: Maximus V Extreme | CPU: i7 3770k
| Memory: 2x8gb G.Skill Trident X 2400mhz | GPU: PNY Geforce GTX 670 | PSU: NZXT Hale 90 750w
| SSD: Intel 120gb 330 series (OS) | Intel 120gb 330 series (Games n stuff)
| Monitor: LG 29EA93 | Cooling: Custom Loop
Jim-M4EZ
With that type of cooling system (CPU & GPU x4) - might want to look into cooling the RIVE's chipset as well ...
... as long as you're doing it ... 😉
You could certainly do a dual loop - a 240 on the CPU & Chipset, & a 420 on the Quad GPUs ...
... or, a single loop with twin 360s - would consider the APOGEE Drive II on the CPU in that case.
fwiw - I don't worry much about what will fit in the case ...
... run my rads externally via the case hose grommets, w/ fans & pumps on an external PSU ...
Ambient room temp is always less than inside case temp - lets the rads work a little better ...
... cooler starting point, so to speak (& so much easier to clean).
Best of luck with it, whichever way you go - sounds like you've got the makings of quite the killer rig ... :cool:
- M4EZ - 1: 3510 - 2: 1004 / i7-2600K / Redline 2133 16GB / Win7 Pro x64
- v.3510 / 8.0.0.1351 - v.8.1.0.1263 / 10.8.0.1303 - v.11.2.0.1006
- RevoDrive3x2 240GB - OS / Vector 256GB x2 RAID0 - OS / Vertex3 MI 120GB - OS / P'9230 3.0 2TB - B/U
- 9260-8i BBU - CacheCade Pro Vertex3 120GBx2 RAID0 SSD Caching - Const ES SAS RAID10 GHS - Data
- GTX580 3GB HC2 / Xonar Essence STX / ST1200G / TJ10B-W / ZR30w / SP 2500 2.1
- Water: Swiftech/Koolance/Tygon/EVGA/MIPS - Wind: SST/Noctua/Cougar
