10-11-2023 07:02 AM
I was getting these fluctuating numbers on my Q-Code LED and I was scratching my head thinking there was something wrong with the new rig I'm building but there wasn't at all. It turns out that in the UEFI under Advanced>Onboard Devices Configuration>LED Lighting the Q-Code LED function is set to Auto which means not only does it show codes but it also shows cpu temperature. So I switched it to show POST code only and then it showed AO which made me extremely happy. I thought I'd put that out there in case anyone else, like me, thought there was a problem when there wasn't one at all.
