push and pull fans for a corsair h50
lostsoul32
hi all ..
i am wondering if anyone would like to share and give some advice i llive in the united kingdom and i am looking at upgrading the corsair h50 fans ...
i have been looking at the akasa fn059 viper fans.. from overclockers.co.uk.. i am wondering if anyone can reccomend them or if anyone would like to reccomend another pair of fans . also i am looking at swapping the haf 922 fans to 140mm fans or are the coolermaster standard that come with this case the best to stick with ..
as a added note i have a zalman fan control in the system .. but would like maxinum airflow but also silent ...
at the present moment i have Scythe Kaze Jyuni 1200RPM Slipstream 120mm Fan as extraction on the top of this case.. so would also like to replace them ...
thanks in advance
Retired
Not applicable
http://rog.asus.com/forum/showthread.php?10285-Show-us-your-favorite-fan-s-(with-motivation).......
I always swap the cors. stocks to the Baldemasters... Have it on H60/H100
Works great on Radiator....
