04-06-2014
08:06 AM
- last edited on
03-05-2024
11:22 PM
by
ROGBot
04-06-2014 08:54 AM
04-06-2014 09:37 AM
04-06-2014 10:14 AM
Cirenitram wrote:
Ever think of removing the outside covers and spray-painting the covers? If you take your time it could be a work of art.
04-06-2014 01:52 PM
Dr. Zchivago wrote:
It occurs to me that this would be the ideal option, unless you have cash to burn - which I would say should be directed at better components elsewhere.
Z
Edit: Honestly, I feel like a high quality PSU looks good with any color scheme, because when people look into the case they can think, "Holy Toledo, Batman!! This guy uses only the best!!"
Just my take.
Edit: Also, look at Seasonic's PSU line - they are pretty color-neutral and are top-notch to boot.
04-06-2014 02:47 PM
04-06-2014 02:54 PM
Z
Just my take.
04-06-2014 03:13 PM
Cirenitram wrote:
+1 on quality
+1 on better components
depending on how old your HX1000 PSU is, it may already be out of warranty and painting will not matter. removing the labels will void a warranty also, no?
04-06-2014 03:20 PM
04-07-2014 03:46 PM
