02-25-2018 07:13 PM
02-25-2018 08:07 PM
02-26-2018 08:30 PM
Raja@ASUS wrote:
If you're looking for plug-and-play, stick with memory kits rated no faster than DDR4-3600. Above that speed, the system may need manual tuning, and there are also some CPUs that don't have good memory controllers.
02-27-2018 01:30 AM
iSAMx wrote:
OK, i don't have any problem with manual tuning I need an answer of my question does the RAM and Motherboard compatible or not will I get 4133mhz in the XMP auto or not?
02-26-2018 09:27 PM
02-27-2018 04:45 AM
