Problem with ROG Gladius II Origin
NNick__power280
Hey everyone,
I've had my ROG Gladius II Origin for over 6 months now, but recently it's been acting up. The buttons technically work, but there’s an issue with the clicking. When I hold a button down, it randomly stops registering – almost like a sensor is being interrupted. This happens with both the left and right mouse buttons. Has anyone else experienced this or know what might be causing it?
Nate152
Hello NNick__power280
Have you installed Armoury Crate? Version 3.2.11.2 (First download) - https://www.asus.com/supportonly/armoury%20crate/helpdesk_download/
I'm sure there will be some updates for your ROG Gladius II Origin in Armoury Crate, updating it may solve any issues you're having.
NNick__power280
It's already installed on my PC's system already. The problem persists no matter what PC you connect it to. The problem is with the device itself.
Nate152
You could try resetting your ROG Gladius II Origin.
1) Connect the cable to a pc usb port and have it close by.
2) Set the wireless switch on the bottom of the mouse to wired mode (switch set to the center position).
3) Press and hold down, Left click, Right click and Scroll click for 5 seconds.
4) With the buttons held down, connect the cable.
5) Your mouse should now be reset, you should have an update in Armoury Crate.
Is it working any better after resetting your mouse?
