Problem with G.SKILL F4-3000C16D-16GTZR memory with RYZEN 2400 (B450M-GAMING)
simmz2k20
CPU : AMD YD2400C5FBBOX Ryzen 5 2400G Processor with Radeon RX Vega 11 Graphics
Motherboard : ASUS TUF B450 Gaming Motherboard (TUF B450M-Plus Gaming)
RAM : G.SKILL F4-3000C16D-16GTZR
Storage : Samsung 970 EVO Plus (MZ-V7S500B/AM)
Graphics : *none* (using build-in Radeon RX Vega 11 Graphics)
Other : EVGA 600 BR Power Supply (BR-0600-K1)
BIOS : Version 2006 (2019/11/25) **CURRENT**
Hi!
As soon as I enable the D.O.C.P. mode to PROFILE 1, the computer P.O.S.T. and not boot anymore. The D.O.C.P. mode detects the appropriate parameters according the the RAM specs which are 3000 Mhz, 1.35V and CL16-18-18-38 timing. If I leave the D.O.C.P. mode disabled and run with the basic settings (1.2V, 2133 Mhz), the computer is working flawlessly.
Regarding BIOS version, please note that I have this problem since the beginning when I built my PC with the ASUS motherboard and G.SKILL RAM (may 2019) and since then I updated like 5 or 6 times the BIOS with the same result.
Any suggestions? I contacted ASUS technical support and they just answer that this specific RAM PN# by G.SKILL is fully supported at 3000 Mhz with my motherboard.
0 REPLIES 0
