Problem w/ GTX 670 being to heavy?
Bemyguest7
I have a Corsair Carbide Spec 02 case with a Asus Maximus VII Hero and a Asus GTX 670 DirectCU II OC. I replaced my EVGA GTX 660 SC with the 670 and there is quite a size/weight difference...i'm experiencing the GPU actually sagging/drooping on the end. I'm worried that it will cause damage to either the mobo or gpu /both...Has anyone else had/seen this problem? Obviously I could rig some kind of support beam for it (lol) but that seams ridiculous.
Thanks for the help in advance!
kkn
Level 14
as long as its secures on the back is OK.
but if you REALY want to have some support on it you can use a thin fishing line so its hard to notice it.
Bemyguest7
Ya ive seen a few guys do that...I think i'll flip the power cables over the card and use some fishing line.
i have 2 670 in sli, on my formula m/b and have not had a problem, just lots of fun gaming 🙂
MOTHERBOARD : ROG CROSSHAIR V FORMULA... bios 1703
MONITOR : AOC 24 INCH 144HZ
PROCESSOR : AMD FX 8350 - 4.4 Ghz
RAM:CORSAIR : XMS 16 GIG 1760 hz
COOLING : DARK ROCK PRO 3
GRAPHICS : ROG GTX TWIN 760 STRIKERS IN SLI
PSU : CORSAIR HX750
X PREDATOR CASE : IN WHITE
Cruicial 256 Gig SSD OS
Cruicial 128 Gig SSD GAMING
FANS.2 Aerocool Dead Silence 140 mm Red top exhaust
2 Aerocool Dead Silence 140 mm Red 1 front intake1 rear exhaust1 Aerocool 200 mm front intake
WINDOWS 7 Ultimate 64 bit
